Weird intermittent grinding noise when braking
Hi all! new here just got a v70 wagon with 188k miles.
When braking sometimes I hear a weird grinding noise. The brakes are new. It almost sounds like the ABS pump might be kicking in intermittently. it doesn't happen all the time.
I thought it may also be a bearing but if it were a bearing it would happen every time right?
Any ideas?
Any ideas?
No the brake pads were replaced because that's what we assumed it was. What gets me is why its intermittent.
Any thoughts? I will replace the fuse and take it for a spin later.
I have this problem also. Took it in to dealer who couldn;t find reason. I believe it is caused by wear on the rotors. Wear leaves a rim on the edge of the rotors causing the disc pads to rub on these rims occasionally. This creates the noise as the pads scrap on these rims and wear them down a bit, so the noise stops for a while. I just replaced my pads and ground the rim off the rotors and the noise stopped.
