Gasoline smell when turning
Old Aug 5, 2025 | 11:55 AM
withersjw's Avatar
Default Gasoline smell when turning
Hi I have been chasing a strong gas smell when I turn the vehicle at a corner. I get it other times eg speed bumps, but rarely while just cruising along or when stationary.
I have been all over the car. Can't see any fuel leaks (I would expect to it smell when stationary and idling if I had a leak in the line or at an injector etc). Fuel rail seems solid no play.
The evap passes the OBD diagnostic (which would say there is not a leak in the fuel evap system)
I have checked the evap purge valve - it's cycling and pulling vapor. I have checked the evap charcoal filters - I can blow through them so the charcoal is not gummed up.
I smoke tested the evap system don't see any leaks - only smoke to come out after feeding it in at the evap purge valve was at the air vent at the back of the tank.
Fuel cap seems to seal ( EVAP readiness passed after ODB code reset - only done to see if the EVAP would pass, and when I was pressuring the tank with the smoke tester there was no smoke released.
Car runs great - no error codes (using VDASH) but the smell makes it difficult to drive (and there is always the concern of fire when you smell fuel)
The car is a 2015 XC60 T5 FWD with 2.0 e-drive motor.
Ready to throw in the towel and take it to the shop. Anyone have any other ideas or had dealt with this before on their Volvo. Thanks in advance.
John,
Virtuoso
Jun 26, 2023 10:34 AM
Laj77
Mar 12, 2023 07:23 PM
Hugh Huntley
Mar 21, 2014 07:15 AM
Rado001
Oct 25, 2012 07:22 AM
tomecsi
Apr 11, 2012 12:00 PM
