2004 XC70 Headlamp adjustment advice
Old Feb 19, 2010 | 01:03 PM
thegor's Avatar
Default 2004 XC70 Headlamp adjustment advice
Recently I replaced my H7 socket that seemed to crumble when I tried to remove it. I was able to buy a replacement socket w/pigtails and splice it into place. During the time the socket was failing it must have created an arc because the bulb and fuse also needed replacing. The bulb was a standard halogen.
I replaced both H7 bulbs with Sylvania Silverstar Ultra White. Now I notice that both bulbs appeared to be aimed much higher than the previous standard bulbs. All I did was replace bulbs as directed. Is there higher beam part of the geometry of the new Sliverstar? Should I adjust the beam lower? It appears these new bulbs are aimed higher than the "high beam" when you flash the lights against a wall.
Any advice?
Johnaldo
Nov 16, 2012 10:04 PM
coyote12899
Mar 9, 2011 11:53 PM
nextproject
Nov 16, 2009 07:04 PM
Stucart
Jan 9, 2009 04:50 PM
CincyStateFreeze
Jul 28, 2006 11:47 AM
