Fuel Pump Check Valve
Old Feb 5, 2010 | 02:11 PM
biagia's Avatar
Default Fuel Pump Check Valve
Hi
I'm looking for an OEM fuel pump check valve for a 1999 V70XC. I refuse to replace the whole assembly when there is nothing wrong with the fuel pump. I need one that can be placed inline as opposed to dropping the back end. I thought some else had posted a solution. Any suggestions?
Old Feb 15, 2010 | 08:21 PM
family XC70's Avatar
I am not sure what type problems you are having, however, when I got home from vacation I had a recall letter from Volvo on V70 fuel pumps. Something about the pump leaking and there may be a smell of fuel in the cabin. Hope this helps.
Old Feb 20, 2010 | 07:37 AM
biagia's Avatar
Thanks but this recall does not cover 1999's. It's a starting problem only. the fuel does not stay in the system but floats back down to the gas tank. Once the car does start it runs out like a top. Not the relay either.
dagonicc
Jul 10, 2015 02:40 PM
xDread92x
Jun 8, 2014 08:12 PM
quickclay
Feb 7, 2014 04:09 PM
jacobB.
Oct 29, 2013 07:30 PM
sd77
Oct 31, 2011 11:55 PM
