2005 XC 70 brake pedal fade
Old Mar 22, 2011 | 11:38 PM
vivi2004's Avatar
Default 2005 XC 70 brake pedal fade
Took 2005 xc in for brake pad replacment. on return, pedal pushes to floor if I hold med pressure on it. Replaced master cylinder to no effect other than losing $500. If pushed to floor with car at standstill car brakes do hold car if accelerator is pushed. With engine off pedal does not fade. Mech says he called volvo and this is "normal". BS as my 03 v70 does not does this nor did the xc prior to work.
Understand ford had a problem like this where accumulator valve was not holding and bled fluid to accumulator.
Any thoughts on this one?
Old Mar 24, 2011 | 08:34 AM
jdp6000's Avatar
The guy the changed the pads obviously screwed up. How did he do it? Sounds like you have air in the system.
J
Old Mar 25, 2011 | 01:56 PM
juanpen's Avatar
It could be obvious but, are the retaining springs properly replaced?
sorry for my english, see more
Swedespeed Forums - Brake replacement problem
Old Apr 7, 2011 | 10:13 PM
Tdog's Avatar
Couple things you may want to check: Look for fluid leaks / having to add fluid. Sometimes when they replace the pads they let the brakes just hang by the hydraulic hoses, could have created cracks and will cause leaks. Also, will need to be bled if any hoses were replaced, I'm guessing you did this anyway when the MC was replaced. If not I use the one that IPD and FPC Groton sells with the original volvo brake fluid. It make sense that this happens when the car is running as that is when the power assist for the brakes is working. Sounds like leak, air (like jpd600 said) or clips (juanpen)
hood1227
Mar 31, 2013 08:34 PM
boxpin
Jan 31, 2012 08:44 PM
AnathemaS80
Nov 12, 2010 11:16 AM
glt93
Feb 18, 2008 08:16 PM
TheJimbo
Oct 26, 2006 11:16 PM
