ABS Computer problem??
Old Aug 26, 2008 | 11:50 AM
pzvt's Avatar
Default ABS Computer problem??
I'm getting the following codes:
P0571 - Brake switch A circuit malfunction
P0504 - Brake switch A Brake switch B Correlation
Is this an ABS computer problem? Brakes work fine. Cruise, trip computer, etc don't work - all kinds of warning lights are lit
Dealer thinks it is the computer
Anybody seen this?
Is there a cheaper place to get a computer ($1000.00 dealer list probably)
Thanks
Old Aug 26, 2008 | 01:42 PM
billofdurham's Avatar
Default RE: ABS Computer problem??
Welcome to the forum.
What year and engine for the vehicle?
P0571 relates to Volvo code ECM9400 which is either a faulty signal or a missing signal from the brake pedal sensor. Symptoms are cruise control not working and brake light continuously on.
Check for problems in the brake control module and the central electronic module. Also check for bad/dirty contacts between the engine control module and the brake light switch; open circuit in the voltage feed to the brake light switch; open circuit or short circuit in the cable to the brake light switch; incorrectly installed brake light switch; incorrectly adjusted brake light switch or damaged brake light switch.
I can't find a Volvo code relating to P0504.
Old Aug 26, 2008 | 07:15 PM
Did the Dealer pull the codes?
I have never seen a Dealer us P codes.
Old Aug 27, 2008 | 06:40 AM
pzvt's Avatar
Car is 2002 XC70 not sure on the engine code - I'll check.
The codes came from my code reader.
The dealer told me their code reader saw ABS issues.
As I understand it 2002 and new ABS modules can not be rebuilt.
Thanks for the replies
Old Aug 27, 2008 | 06:38 PM
Did you check the places that rebuild them yourself?
The 2003 or 2004 are the newer different style.
Old Dec 4, 2009 | 05:46 PM
volvo2002's Avatar
Default ABS ECU ISSUES P0571 and P0504
I'm having same problem on 2002 s60 AWD. I got the same p-codes, same behavior. Please let me know if you were able to fix your vehicle.
Brakes work fine. (Cruise, trip computer, traction don't work)
Thanks,
Old Dec 4, 2009 | 09:26 PM
Thanks,
Sounds like the common bad ABS module.
Old Dec 11, 2009 | 07:50 PM
redz1006's Avatar
Got this same issue this week. When you turn off and turn on engine the warning will go away. Until it came to a point where the message stayed (Engine System Service Required) and amber triangle is on. Odometer is also screwed up (shows dashes only) and cruise control too.
I was able to pull down P0571 code and also was able reset/erase it.
I put a new brake position sensor today but problem still persists.
It feels like there is really nothing wrong with the car except for the code. Is it safe to assume that it is still OK to drive the car in its condition when the warning message is up ?
I dread that this is a BCM failure. It costs around a grand in this MY (04) of the S60
Any ideas will be much appreciated. Also thinking of taking it to the dealer for full diagnostic.
Old Dec 11, 2009 | 09:58 PM
Your might be the brake pedal sensor.
Old Dec 13, 2009 | 04:40 PM
deucetech's Avatar
ECM 9400 is usually the brake pedal sensor in the booster (not on the pedal itself). Ive seen some rebuilt BCMs but the cost is almost the same and usually contain less of a warranty.
Old Dec 14, 2009 | 11:07 AM
redz1006's Avatar
Took the car to the dealer to get Volvo specific codes pulled. I held off on replacing the brake pedal sensor. I did replace the brake position sensor but that obviously did not fix the problem.
Will give un update maybe later today when I get the exact volvo codes.
Old Dec 14, 2009 | 02:17 PM
redz1006's Avatar
Got the codes back.
Still pretty generic and all seem to point to bad BCM
ECM-9400 Brake control module (BCM). Faulty signal
ECM-9400 Brake pedal position sensor, faulty signal.
BCM-0052 Control module. Internal fault
CEM-1A5F Communication with the ABS control module. Signal missing. Intermittent fault
Dealer quoted $1800+ to replace and reprogram
Old Dec 15, 2009 | 08:54 PM
WOW that is alot!
Old Dec 16, 2009 | 10:00 AM
redz1006's Avatar
WOW that is alot!
Yeah. So I'll be driving without ABS for a while
The BCM for our MY(I think starting from 02) cannot be rebuilt and it will require reprogramming if I get a new one or a salvage part.
Might try and find an indy or specialist shop around here that would do it for less.
Old Dec 16, 2009 | 07:15 PM
If you can find a used one cheap give it a try. I think a few years ago we changed out a used module in a car and it was fine.
Old Feb 2, 2013 | 02:00 PM
Westy84's Avatar
Default ABS works until driven at 35mph
My 2002 XC70 ABS suddenly stopped working. CEL pointed to wheel sensors, replaced the one that was marginal based on ohm resistance reading. Problem persisted, so pulled module and sent it to Midwest Modules for a diagnosis. The mod checked out fine, but he was able to pull two codes, low voltage and pedal position sensor. Since the unit didn't need to be cracked open, he charged me a very reasonable fee for his excellent and super fast service. I'm going to replace the switch from FCP Groton, however they do not show the switch available for the 2002 xc 70. Does anyone know if it is the same switch as the 2002 v70, which FCP has for around $110?
If you do pull your module, it is better to have it repaired... As replacements require costly reprogramming to match to your 2002 or newer Volvo. Midwest Modules provided exceptional service and guidance, I highly recommend them.
When pulling your module, the wiring harness requires that the housing be slid back to release the plug. It is highly recommended that you disconnect the battery and not drive the car with the module out.
Note: codes stored in the ABS module can not be pulled from your typical OBD2 code reader.
larry_s
May 15, 2011 04:24 PM
ticedoff8
Jan 8, 2010 08:35 PM
George S80 99
May 15, 2009 10:13 AM
S70driver
Feb 24, 2008 10:59 PM
robohopar
Sep 27, 2007 11:37 AM
