Auto transmission issue
Old Dec 24, 2023 | 09:12 AM
paulmonkton's Avatar
Default Auto transmission issue
Transmission issue . Car is fine when cold .when hot after about 25 mins and put in reverse after about 2 seconds it bangs in to gear oil was like black engine oil .dont think ever been changed 06 model 190k done a drain and fill 5 times and fluid still browney red . Not like the red as it goes in new . .new to the forum got a manual which is great but also got an auto was warned of a gearbox issue .thought I take the gamble as like an auto ! Any ideas
Old Dec 24, 2023 | 06:57 PM
did you also drop the pan and inspect the pick up and look for debris? (debris being bits of the wet clutch)... You may be able to clean the screen/filter to help improve but it may be in need for a major service or replacement assuming you want to solve the hard shift. The other possible cause is a weak solenoid - google around for common symptoms but the solenoids can be replaced with the transmission in the car.
Scrapperdave
Oct 2, 2023 11:11 AM
Daddy Wagon 3
May 2, 2017 12:42 PM
kevinger
Aug 20, 2013 04:05 PM
Psaboic
Sep 18, 2006 08:35 PM
