Bi-Xenon head lamps
Old Dec 17, 2006 | 02:49 PM
traveltoad's Avatar
Default Bi-Xenon head lamps
I have recently purchased an '07 XC70 with the Bi-Xenon headlamp option. This option replaces the low beam with the Xenon light which is both low and high beams. The separate, standard, halogen high beam bulb is left in the housing all wired up but does not come on. I assume that the ECU program is changed when the Xenon option is installed effecting this change.
Is there a way (other than wiring a separate circuit) to have both the Xenon high beam and the standard halogen high beam both come on?
Old Jan 22, 2022 | 05:49 PM
fogbert's Avatar
I beleive thatis a failure of some kind. I have a '07 XC 70 with the Bi-Xenon option, The separate High beam Halogen used to work, but has stopped. Having it checked out by a mechanic next week. I suspect a bad relay.
Old Jan 22, 2022 | 05:51 PM
Isn't the inner bulb the daytime running lamp? (with a Zenon outer bulb) Or have your daytime running lamps been turned off?
Old Jan 23, 2022 | 12:26 PM
fogbert's Avatar
IDK, the owners manual does not make it clear which light is the drl. There is no switch setting that illuminates the halogen in the inner light.
Old Jan 23, 2022 | 12:43 PM
What lights are on when the switch is in the off position? If none front or rear - someone has turned daytime running lamps off using VIDA or a compatible scan tool. I've done that with all my cars when possible - makes the bulbs last longer and you always have the option to leave your lights on if desired.
Old Jan 23, 2022 | 01:05 PM
fogbert's Avatar
Default Brights/DRL ?
Based on my owners manual, p199 that inner light with the Halogen is the high beam when cars have the active BiXenons low/ high beams.
Also noticed that the self adjusting motor no longer moves the lights when first turned on, side to side is fine. I’m starting to suspect an upstream issue ( ballasts, relays, or stalk/ switch)
Turbogirl7
Feb 6, 2024 06:37 AM
cunning
Nov 9, 2018 07:54 AM
arfstrom
May 2, 2017 09:56 PM
branse
Aug 15, 2014 09:04 AM
hgshaw
Jan 1, 2014 02:59 PM
