Help! What is this engine rattle?
Old Dec 7, 2022 | 03:01 PM
Bruno DelVecchio's Avatar
Default Help! What is this engine rattle?
12 Volvo XC70 3.2. Anyone have an idea what this rattle is? It's coming from around the intake manifold area. Have a listen. (Sound file is attached)
File Type: mp3
Old Dec 7, 2022 | 05:46 PM
not a clue from listening to the audio. Suggest a few things - does the vibration change with engine speed? Can you feel around for any loose trim or components? Have you popped off the covers to the coils, the timing belt cover etc to see if the sound changes? You can also try using a hose or a tube as a listening device to see if you can pin point a source area and go from there (lol, stickin your ear close to a running engine is not advised).
Old Dec 8, 2022 | 03:13 PM
Lol, I learned that lesson the hard way a few years back. I used a Lisle stethoscope to pinpoint the sound coming from the intake manifold. Turns out, it was a piece of plastic from the intake actuator that was causing that ruckus. Dislodged itself from the actuator motor and made its way to the intake entrance flapping around wildly. It's a miracle it didn't go into the engine
Old Dec 8, 2022 | 03:40 PM
glad this worked out. Thanks for sharing the update.
Zona55
2001-2013 model year XC70
Aug 8, 2012 10:18 PM
treumb
Apr 22, 2008 09:05 PM
kmg2005
Mar 4, 2008 08:25 PM
alpine
Jul 12, 2007 12:32 PM
matthewensey
Sep 12, 2005 08:31 PM
