Urgent brake failure
Old Apr 8, 2009 | 10:12 AM
PopeyeXC70's Avatar
Default Urgent brake failure
I just received warnings indicating stop carefully.
Brake failure, SRS sytem inspection.
All ligths flash, then the dashboard goes completly blank while driving...No spedometer/odometer/tachometer/AMMETEr/Fuel Gauge, etc. Dark!!!
The car runs perfectly fine and the brakes work fine.
I have a brother that owns a digital reader, will that tell me what is wrong and what I need to repair/replace???
How can I keep driving until I am able to get the work done?
Old Apr 8, 2009 | 07:29 PM
I will bet your ABS module is bad.
Old Apr 8, 2009 | 08:16 PM
Johnny Mullet's Avatar
Sounds like an ABS module to me also. Pretty common issue, but the crazy blank dash? Did it come back?
Old Apr 9, 2009 | 06:31 PM
PopeyeXC70's Avatar
Default ABS Module.
Thanks.
Yes. My dash will flash every once in a while give me the warnings and then black out again.
I don't know why the module would cause this.
I saw that There is a abs system reader that you can get at Autozone but it does not say specifically for Volvo. Would it work...Is it worth the investment?
Old Apr 10, 2009 | 11:17 PM
Not sure if it works or not.
It affects the dash because it is a computer in a network and it is after the ABS module.
Sssnake
May 27, 2022 06:55 AM
Brittanie
Apr 3, 2019 08:36 AM
CASS60
Apr 3, 2019 08:29 AM
robingichuhi
Feb 22, 2017 04:34 PM
oalsa
Nov 16, 2005 10:45 PM
