vibration/roughness hardleft
Old Dec 29, 2007 | 04:49 PM
nebsch's Avatar
Default vibration/roughness hardleft
When I make a hard left under acceleration I am getting a roughness/vibration from the front right of the car. It sounds like it is coming from the wheel. It only happens when I do this somewhat aggressively or in a corner that exagerates the weight on the front right of the car (e.g. down hill on an offcamber corner). Any suggestions for the cause, severity and cost to fix?
Old Dec 29, 2007 | 05:13 PM
Default RE: vibration/roughness hardleft
Maybe a bad axle or wheel bearing?
Old Dec 30, 2007 | 10:38 AM
Psaboic's Avatar
I vote the same way..... However I would definitely suspect a wheel bearing if the vehicle has over 75K on it. Cost?? Depends on who does the work
Old Jan 9, 2008 | 12:16 AM
nebsch's Avatar
I'm thinking bearing now too. Now there is a high pitch hum between 50 and 55 mph coming from the same wheel. It looks like you have to replace the whole hub/bearing assembly. The part isn't too expensive and this is typically not too involved a replacement, however does this require special tools to perform the replacement, or is it especially complicated in this vehicle?
zero324
Jan 26, 2019 10:08 AM
lhfgracebanet
Mar 27, 2009 04:47 PM
ocean238
Apr 17, 2008 06:20 PM
FLYNAVY
Mar 11, 2008 04:01 AM
mido
Jul 8, 2007 01:27 AM
