Wiper Reservoir
Old Oct 29, 2010 | 11:36 AM
lisa's Avatar
Default Wiper Reservoir
Hello
Just bought a 2008 XC70, The light on the dash for the Wiper fluid came on and when i got home I added the quarter of a jug the I had left over to the Reservoir. Everything is fine until my wife came out and noticed that it all came out under the car. Now I didnt spill a drop, I tired to look under and cant see anything. any ideas on what the issue could be> It must still have some in it cause I did try the wipers and they worked fine. Thanks
Old Nov 16, 2010 | 10:29 AM
Rosew6211's Avatar
Are you sure all came out or just what spilled out from overfilling the reservoir. The fill neck of the reservoir can leak where it enters the reservoir. The pump on this model is under the reservoir and pulls suction throug a tube going thru bottom of reservoir. If you didn't overfill, the only other two causes are: Crack in reservoir tank or leak at pump connection in bottom of reservoir. I feel you just overfilled and don't have a problem. This can easily happen, particularly if the resevoir neck is't leak proof sealed at reservoir. Suggest you just pull the reservoir neck out and see if the reservoir is filled.
Old Nov 21, 2010 | 11:16 PM
xc70hans's Avatar
About one month ago, my 2008 XC70 started the same game. Every time I turn on the ignition/start the engine the system puts up the note to refill the washer fluid. As all such info notices do, it disappears after 30 seconds or so. I am planning to raise the issue with my dealer at the next oil change. It's a certified vehicle and the warranty should cover that problem. I'll report back when I have an answer.
Hans in Minneapolis
Old Nov 23, 2010 | 10:59 AM
tr_car_nut's Avatar
I had this same problem with my 2003 S40. Now it is probably slightly different on the 2008 XC70 but you might want to check to make sure the sensor on the reservoir tank is properly inserted into the tank. Mine was put in upside down so every time I filled the tank it would leak. I would look from underneath the car while someone fills the reservoir from up top. You might be able to see where it is leaking while it is being filled.
JPN
Dec 29, 2013 10:57 AM
850forum
Dec 24, 2011 11:19 AM
KS70T5M
May 10, 2010 07:52 PM
rdharper
Mar 12, 2007 06:42 PM
Bklyn
Jan 11, 2006 12:28 AM
