07 XC90 Brake Failure - Stop Safely
Old May 14, 2017 | 06:28 PM
nyc1836's Avatar
Default 07 XC90 Brake Failure - Stop Safely
About 6 weeks ago we drove the SUV from Texas to Miami stayed there 2 weeks and came back total about 3000 miles the anti skid service and DSTC came on several times car drove fine the other night my wife was 5 minutes from house started car abs check engine and other lights came on she told me to check.I tried to start car no luck Brake Failure - Stop Safely.My friend mechanic checked battery and also tried starter from under car starter and battery good.We got the ABS module with pump and tried to hook up the plug to the new one did not disconnect old hoses yet same thing.We ere not able to get a good obd reader yet mine that I have says error.My question is do I have to reset codes in order for it to work did any one hear that if the Brake Failure - Stop Safely goes on it wont let you start car any advice please
Old May 14, 2017 | 08:51 PM
schumicat's Avatar
you need to get a volvo specific code reader that can communicate with the car's systems rather than a generic obd 2 reader. you can get a carsoft one on ebay for around $100 or a shop that specializes in volvo should have that or better (the dealer version), vida/dice. it sounds like you voltage bad but you checked that... another possibility is the CEM ; do some searches but it isn't good if that's what it is.
Old May 15, 2017 | 02:31 PM
nyc1836's Avatar
Just to be clear which is a better choice carsoft or vida/dice? Also will it work if call not running ignition goes on but wont start I guess it should
Old May 15, 2017 | 09:39 PM
nyc1836's Avatar
We just hooked up snap on obd computer and got this ECU needs to be determined to correctly identify this system switch ignition on.ignition is on lights on etc fan works seems like computer not communicating with obd any advice if I get VIDA DICE if there is no communication with ECU (bad) will I get better information of problem any advice?
ecf
2001-2013 model year V70
Feb 17, 2018 12:45 PM
PapaBruce
2001-2013 model year XC70
Sep 30, 2014 06:43 AM
Pos392@yahoo.com
Jul 5, 2012 10:26 AM
Pos392@yahoo.com
Jul 3, 2012 02:58 PM
powerwagon80
Dec 19, 2008 09:17 AM
