2004 xc90
Old May 13, 2019 | 02:05 PM
Captjoe12256's Avatar
Default 2004 xc90
Driver side door won't close.
Old May 13, 2019 | 09:56 PM
won't close meaning its misaligned or the latch is not holding the striker screw? see if you can manually set the latch (ie with the door open, move the latch to see if it will stay in the closed position. If not you'd need to open up the door to see what is jambing the latch mechanism. If its misaligned, you'd need to check the hinges to see if bolts are loose and readjust as needed or see if there's damage from an accident or broken/worn pins.
Submoofer1
Nov 19, 2012 12:37 AM
ovloV7098
1998-2000 model year V70
Jun 30, 2012 07:15 PM
jeffrodw
Jun 2, 2012 12:17 PM
klod622
Jan 31, 2010 06:11 PM
volvodan
Dec 18, 2006 09:16 PM
