2005 XC90 Key won't turn off
Old Apr 12, 2021 | 12:01 AM
wparry's Avatar
Default 2005 XC90 Key won't turn off
2005 XC90 Automatic V8 FWD
Car sat for a year or two, I just got it. I had to press the white button down under the shifter to get it to shift. Now it shifts and drives fine. But when I parked after the test drive the key won't turn off, stops half way between 0 and 1. Car can start back up and shift again and drive no problem, but I had to disconnect the battery and leave the key in it. Any one had this one before? Is it a problem with the shifter/linkage/tumber? Any info is appreciated.
Old Apr 12, 2021 | 10:02 AM
If the shift **** is not pressed all the way down that can happen. That is the whole **** needs to be pushed down - so whack the top of the **** gently with your hand - and see if that helps (the **** is simply pressed on, and sometimes gets pulled up slightly when people get frustrated when they cant get it out of park.)
Old Apr 12, 2021 | 11:33 PM
wparry's Avatar
Thanks hoonk, I gave that try but no luck. But I did figure out that if I flip that white switch up under the shifter that I pushed down to get it to shift out of park then it releases the key. However I need to push the switch down again to drive. I'm guessing this means it's the white switch?
Dclester13021
Mar 2, 2019 03:47 PM
trek8288
Jul 20, 2018 02:03 PM
ianreid
Dec 2, 2012 08:21 AM
cooness
Dec 8, 2010 06:30 PM
harryangus
Apr 6, 2010 10:01 PM
