2005 XC90 rear wiper doesn't touch top of window
Old Feb 18, 2019 | 09:51 PM
Harry Paratestis's Avatar
Default 2005 XC90 rear wiper doesn't touch top of window
The rear wiper blade does not make even contact wth the top half of the window. I tried "tweaking" the arm and ended up snapping it off. I replaced the arm and wiper and it still misses the top portion of the rear window. Any ideas? if it was a metal blade I would just bend it a bit.
Old Feb 19, 2019 | 08:37 AM
is the wiper motor seated properly or loose? Usually replacing the wiper arm should fix the contact issue as you are getting a new tensioner spring so the only other cause I can think of is that the motor shaft is at the wrong angle.
Old Feb 19, 2019 | 04:58 PM
That's what I was thinking. never had this issue on my 2003 xc90. I'll look at it a little closer when it warms up
arfstrom
May 13, 2017 08:40 PM
Beemer2002
Jan 21, 2010 09:52 AM
HummerGuy
Dec 28, 2008 01:37 PM
03v70
Jan 18, 2008 08:32 PM
Jkohut902
Sep 12, 2006 11:54 PM
