2006 low beam bulb failure
Old Mar 29, 2015 | 07:20 AM
maxxheadroom's Avatar
Default 2006 low beam bulb failure
I have standard running lights (no ballasts). Passenger side headlight is intermittent. I replaced the bulb. Made no difference. What's the deal??
Old Mar 29, 2015 | 08:33 AM
pkrface's Avatar
You have a broken wire (or a bad connector) somewhere that sometimes makes a connection and sometimes not. The only thing the ecm knows is there is a broken circuit as it is only looking for continuity. Have you ever had a light bulb where the filament is broken, but when you shake it the connection is re-established and the light will work until it is shut off and the filament cools down and separates again? Same thing.
Old Mar 29, 2015 | 08:43 AM
Default makes sense
That makes perfect sense. I will inspect closely today and report back. Thanks
Old Mar 29, 2015 | 09:25 AM
cn90's Avatar
I posted info on mosfet (inside the light control module) controlling the lights.
If you get to that point, you will need to solder the new mosfet in.
Old Mar 29, 2015 | 09:35 AM
ES6T's Avatar
Take a close look at the connector. Its common to melt.
Old Mar 29, 2015 | 10:07 AM
Sounds reasonable. Please tell me more. Where is your post? Where is the Light control module? I'm a former electronics tech. I am a very capable solderer.
Old Mar 29, 2015 | 10:10 AM
I replaced the bulb thinking that was the problem. I have heard when they melt...they melt good. Mine appears ok, but I will take another look. Thanks
Old Mar 29, 2015 | 01:02 PM
Default I think it's fixed
I checked voltage at the plug. It was good. I looked inside the bulb plug and there was a wide gap for the tiny bulb pins (not making contact). When I tried to fix it, the plug crumbled in my hand. I bought a $10 plug replacement at O'Reilly's and it's working again.
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
marucusu
2001-2013 model year V70
Nov 3, 2012 11:49 AM
billveld
Sep 13, 2011 02:58 PM
2005s60
Jan 19, 2011 01:50 PM
llcoollam
Apr 24, 2006 06:54 PM
