2006 Volvo XC90 2.5t Engine surge with a/c on?
Old Jun 6, 2015 | 11:54 AM
kclarke's Avatar
Default 2006 Volvo XC90 2.5t Engine surge with a/c on?
I have a 2006 XC90 2.5T, The engine will surge only when the a/c is on. I can feel it drag when I am driving down the road, and when I stop. You can see the rpm's going slightly up and down......Is this a sensor issue or possibly low on freon? The clutch on the a/c is engaged when this surging happens!
Thanks
Old Jun 6, 2015 | 08:47 PM
damien360's Avatar
Whenever you have the A/C on it is just another load on the engine. Try cleaning the throttle body and see if it goes away.
Old Jun 6, 2015 | 08:50 PM
kclarke's Avatar
Thanks for the reply, I will try this tomorrow!
Old Jun 11, 2015 | 09:41 PM
volvoxc9O's Avatar
My 2.5t was doing this and at stops it was very noticeable. I replaced the pvc system and clean the trottle body and it went away. It is a little of a pain to get to, compared to other n/a engines I worked on.
Old Jun 12, 2015 | 11:06 AM
kclarke's Avatar
Thanks volvoxc90, when you said you replaced the pvc. is it the pcv tubing that you replaced, did you just spray the throttle body with carb cleaner? I will attempt this this weekend...
Thanks for the info
Old Jun 12, 2015 | 04:13 PM
volvoxc9O's Avatar
Yeah I replaced the tubing, charcoal canister under the manifold, but u should try to clean the throttle body first sense is the easiest and cheapest solution, see if that does the trick I just happen to do both at the same time due to the fact that i also had smoke coming out the dipstick which normally indicates a clogged pvc system.
Old Jun 12, 2015 | 07:44 PM
kclarke's Avatar
Thank you for sharing this, I should have asked you this, this only happens when I have the a/c on, when the a/c is off, it runs great....is there a possibilty that it need more freon? Sorry for all the questions
Kevin
Old Jun 16, 2015 | 06:57 AM
volvoxc9O's Avatar
Well if its low on freon it causes the ac clucth to engage and disengage more often on the compresor and if thats the case u problably have a small leak somewhere , u could try buying a can of freon she if it works but im afraid the issue would return eventually as the freon leaks out.
Old Dec 26, 2016 | 12:02 AM
SWEEDISHgenie's Avatar
Kevin
If your clutch is going out on your compressor it can add an extra load. If all else dails you could replace that
bradnight
Jan 4, 2011 12:06 AM
brf0007
Jan 11, 2009 11:59 AM
calas60
Jul 31, 2007 09:29 PM
go2sharks
Mar 6, 2007 06:03 PM
ttron
Nov 8, 2005 01:14 AM
