2008 3.2 - massive oil leak passenger side
Old Nov 28, 2019 | 03:45 PM
Beatums's Avatar
Default 2008 3.2 - massive oil leak passenger side
3.2 awd with 285,xxx miles.
So I've developed a massive oil leak on the passenger side of the engine. As soon as car starts oil can be seen pouring out of the weep hole at the end of the crankshaft. Is this the front or rear main seal? Crankshaft seal? Are those the same thing?
is this vehicle done for? Lol.
Old Nov 29, 2019 | 11:49 AM
ES6T's Avatar
Weep hole? If you can see the end of the crankshaft, you are missing the front plug.
Old Nov 30, 2019 | 02:19 AM
Beatums's Avatar
Yes I guess I am missing the plug. I can see the end of the crankshaft.
it is leaking oil like crazy from that tiny hole below. Everything I'm finding on the web is the timing belt side of crank. Can't find any info on this side of crank
are you telling me all I need is that $10 plug?
is this serviceable from outside of the engine or does it need to be torn apart?
Old Nov 30, 2019 | 07:23 AM
ES6T's Avatar
Yes, there needs to be a plug there.
Old Nov 30, 2019 | 10:19 AM
Beatums's Avatar
dumb question on my part that was kind of obvious lol.
but is it serviceable from outside the engine or does it need to be torn apart?
Edit: i got the part. Looks like it just presses into there. But what is supposed to hold it in place?
Old Dec 1, 2019 | 01:16 PM
ES6T's Avatar
Just remove the passenger front wheel, pull the fender liner away for access.
Clean the area. Put some lube on the new one and press it in. I've never seen one come out. I wonder if your PCV is clogged or you have excessive blow by. Might want to use glass cleaner or similar to lube it so that it will evaporate once in place. Then check for excessive crankcase pressure.
Old Dec 1, 2019 | 11:24 PM
Beatums's Avatar
I've replaced the pcv oil trap already. There is obviously pressure still though as it keeps dislodging.
Old Dec 2, 2019 | 06:39 AM
ES6T's Avatar
It keeps dislodging after being properly installed? Or you can't get it fully seated?
Robert Bostic
Jul 8, 2018 05:56 PM
doublearon
Jun 13, 2017 06:07 AM
JoeCool850
Dec 9, 2015 12:53 PM
dsharp
Nov 16, 2010 02:34 PM
JPizano23
Mar 3, 2008 06:51 PM
