2012 XC90 AC fan runs with the key off
Old May 30, 2017 | 10:08 AM
gstolting's Avatar
Default 2012 XC90 AC fan runs with the key off
I have an issue with my XC90. My battery gets run down if I don't drive my car for a good period each day.
I have noticed that the AC fan in my car runs periodically when the car is turned off. Has anyone experienced this issue and if so what was the fix for this.
Old Jun 12, 2017 | 09:30 AM
banyanleaf's Avatar
AC fan? Are you sure it is not the cooling fan for the engine? It does come on when the engine runs hot. It is a design to protect the parts under the hood.
Old Jun 12, 2017 | 03:21 PM
Grey Bearded One's Avatar
My car kicks the blower on about an hour after I shut it down if the A/C had been run. This blows moisture out of the system. Maybe your computer is confused.
Old Jun 23, 2017 | 06:18 PM
rudva's Avatar
Well mine sometimes turns on the blower on cabin after I turn off and the engine is not running (car off).
Itis normal?
Old Jun 23, 2017 | 11:25 PM
ES6T's Avatar
Yes, it is normal. It shouldn't do it if the battery voltage is below a certain level. But if the battery is weak, it could cause problems. Have your battery tested and replace it if needed.
Old Aug 9, 2017 | 10:51 AM
banyanleaf's Avatar
ES6T is right, possibly always right.
Confirmed that the A/C fan will run if the inside temperature is too hot even when the key is removed.
Old Aug 9, 2017 | 11:32 AM
ES6T's Avatar
It isn't because the inside temperature is too hot. Its to dry the evaporator case to prevent mildew
mikev40
Sep 28, 2014 08:01 PM
brent@fluidequipment.com
Aug 17, 2014 12:32 PM
urdrwho
Jun 26, 2014 06:39 AM
jbearce
Jun 10, 2013 01:50 PM
redfirefreaky
Oct 23, 2008 09:17 AM
