ac issue on xc90
Old Jul 29, 2008 | 09:06 PM
jtl180's Avatar
Default ac issue on xc90
can anyone tell me if the front expansion valve controls left and right AC flow
jtl180's Avatar
Default RE: ac issue on xc90
dealer says that will fix my issue of passenger side blowing warm air and drivers side blowing cold
Old Jul 29, 2008 | 09:07 PM
jtl180's Avatar
it has been in the shop 4 prior times for the same symptoms, all with a different fix... o ring, gasket, seal... i think it is the blend door/motor
Old Aug 11, 2008 | 06:32 AM
S70driver's Avatar
TTT, Tech please try to help this person.
Old Aug 11, 2008 | 05:36 PM
Could be low on freon or blend motor needs to be calibrated. Try turning the R/S temp to hot then back to cold and see if it changes.
Old Aug 12, 2008 | 05:04 PM
jtl180's Avatar
thank you for the reply..
i did try the r/s gauge trick of going cold to hot for 30 seconds and then back. it does not improve unless i am at highway speeds.
the freon is showing fully charged at 45 pounds
i spoke with the head of the dealership service dept and they are going to look at it again thursday for me.
will post their findings.
Old Aug 12, 2008 | 06:00 PM
If the freon was not pulled out and filled back up to proper specs it still might be low. They can act like this only .50 lb low.
Old Aug 14, 2008 | 06:48 PM
jtl180's Avatar
i had it back in the dealership today and they replaced 5 different "O" rings and replaced the freon.
it was at half the recommended levels.
since they misdiagnosed it the first time as an expansion valve issue, they did the work for free.
thanks for your help
Old Aug 15, 2008 | 06:19 PM
Glad it is going now.
acpenn
Feb 25, 2014 06:50 PM
Earthfromorbit
Jun 15, 2011 03:14 PM
jtl180
Jul 29, 2008 09:07 PM
rsd911
Jul 4, 2008 12:02 PM
audiobiz
May 29, 2008 04:09 PM
