Blower motor advice
Blower motor advice
Parked my 2005 T6 for a week (in Montreal) while on vacation (Arizona). When I started it up there was not heat coming from vents. Did not matter if I chose windshield defrost, floor, or mid vents despite the led on the fan showing various fan speeds. I thought for sure based on other posts that the blower motor was gone (I checked fuses and all was good). I started the engine to move the seat back to start dismantling the interior to try to remove the blower motor and all of a sudden the fan started working again.
My question is what should I do now? Should I still replace the blower motor? Could it be something else? If I replace the blower motor does anyone have recommendations on OEM vs. aftermarket?
Thanks in advance
Thanks in advance
I checked the manual for all fuses related to heating/cooling the interior and then pulled them.
The weather did get a little warmer today when the blower started to work. Have you ever heard of a blower motor stopping when the weather gets cold and then all of a sudden start working when the weather gets warmer? Basically the temp went from -10deg Celsius to -5deg Celsius
timer00
02-16-2009 10:38 AM
