A/C doesn't work on idle
Old Apr 26, 2016 | 04:23 PM
rudva's Avatar
Unhappy A/C doesn't work on idle
The system is charged, the fan looks working, but the a/c works well only when the cars is moving. What is it?
We think it works well if the "rear ac" is on, but that's not normal anyway.
The system is charged, a autozone tester say overloaded but thegauge of a technician says is ok, then who knows. The fan is working and the car never goes overheat, then I guess that fan is working good.
Any clues?
Summer is close!
Old Apr 27, 2016 | 09:04 PM
arfstrom's Avatar
I had my system overcharged, until it made the engine run rough, (04 Saturn ION3) I found a local shop that was doing A/C Checks, and they were able to bring it back to normal. Then pointed out that there is no leaks, because it was over pressurized, so it was good. Hope that helps.
Tobie
Old May 2, 2016 | 04:33 PM
rudva's Avatar
Default Was the compressor
At the end I pass the car with the guy with the A/C machine, that wich vaccum gas and air, the recharge it and test the pressure... Doesn't work... The compressor is not working.
Old Jun 2, 2016 | 03:51 PM
rudva's Avatar
Default Does anyone knows about a video or instructions how to change it?
Does anyone know about a video or instructions how to change the compressor. Is not located like the others volvo engines
Nic Graner
Jan 5, 2013 10:39 PM
ajju_kwt
Aug 8, 2006 03:46 PM
jay philoon
May 14, 2006 07:25 PM
EmailBenn
Oct 9, 2005 09:05 AM
Nand12
Oct 5, 2005 09:59 PM
