Coolant leak from turbo
Old Jan 13, 2023 | 08:36 PM
Look4It's Avatar
Default Coolant leak from turbo
I have a 2004 XC90. Today I noticed all the coolant was empty. I filled it up and it was completely empty in minutes. It looks like it is leaking around the turbocharger. Should I replace the whole turbocharger or is there maybe a bad hose or gasket?
Old Jan 13, 2023 | 10:42 PM
really depends on what the cause is but you may need to pull off the turbo to figure it out. Could be a seal, could be an expansion (freeze) plug. Can you get under with a light/mirror to get a better look as to where its leaking from? You didn't mention how many miles on the car but if the turbo is coming off, it can also be rebuilt with new seals to extend its life. Rebuild kits run about $50 and there are vids on Youtube which show the process.
Greshams
Dec 5, 2022 01:41 PM
volvoguy17
1998-2000 model year V70
Feb 15, 2016 08:06 PM
Dooch
Nov 15, 2014 07:51 PM
lor3nzod
Oct 21, 2012 09:39 PM
schuckles
May 31, 2010 09:37 PM
