Engine Surges and acceleration is not smooth
Hi, I will appreciate if I can have some help from this forum.
My XC90 220000 KM On it started to surge. While Idle when I accelerate which is not smooth, but when I reached over 80 KM it becomes smooth.
First I thought there must be some head gasket problem because when I changed spark plugs year ago I saw oil around plugs. But now when I checked the plugs they are pretty clean, then I changed the coils but no difference. By the way when I disconnect coil 5,4,3 left to right no difference but when I disconnect 1,2 it does shakes.
Now my next suspect is injectors, Pressure test and Turbo Boost Valve.
what can be the culprit? please advise.
fhsscrballa
06-04-2012 03:23 PM
