Fuel Pump Relay
Old Sep 18, 2018 | 02:49 PM
WillieWillie's Avatar
Default Fuel Pump Relay
Hello everyone, hope all is well. I have a 2005 Volvo xc90 v8, it shut off while driving home yesterday. It turns but it will not start, I have changed the fuel filter and still have the same problem. I have been looking for the fuel pump relay with no luck, I checked all the fuse panels and nothing. Can anyone please advice where is located, thank you.
Old Jan 7, 2019 | 09:36 AM
Riker.'s Avatar
Default Similar Problem
I have an 05 xc90 V8. I stopped it after coming home and went to start it the next morning and no go. If i leave it for a few days and try it, it almost starts, but then it just cranks.
Now reading some other posts, they mention a bad battery as the culprit. Could this really cause it not to start? I have a fuel pump and pressure regulator waiting in the wings in case its needed. I am also looking for the fuel pump relay location.
Old Jan 25, 2020 | 05:01 PM
JJ1980's Avatar
Default Driver side cargo area
[QUOTE=WillieWillie;465657]Hello everyone, hope all is well. I have a 2005 Volvo xc90 v8, it shut off while driving home yesterday. It turns but it will not start, I have changed the fuel filter and still have the same problem. I have been looking for the fuel pump relay with no luck, I checked all the fuse panels and nothing. Can anyone please advice where is located, thank you.[/QUOTE
it’s behind rear cargo panel on drivers side in wheel well
adams6904
Jan 25, 2020 05:10 PM
joshlee
May 7, 2019 05:28 PM
kennedy759
Sep 11, 2011 12:16 PM
spidersilva
Aug 17, 2011 07:23 PM
