HELP!!! 2005 VOLVO XC90 gear selector service required
Old Mar 22, 2016 | 08:26 PM
skodamk's Avatar
Unhappy HELP!!! 2005 VOLVO XC90 gear selector service required
Hi guys I really need your advice I have a 2005 Volvo XC90 V8 AWD I recently had problems with the transmission and I was able to get it replaced coasting me an arm and a leg now the car just decided to die on me I was driving home today and I stopped trying to park I put the car in Reverse but it wouldn't go back I put back on drive and it wouldn't move its like the car is not on a gear at all I turned the car off and on and I got a message saying GEAR SELECTOR SERVICE REQUIRED I opend the shifter assembly but everything seems to be in place the shifter moves and it displays on the screen the change between P R N D but when I put it on the manul it shows 1 but wouldn't shift up usually I could shift up to the 3rd gear from a full stop I was just trying to see if it works I don't know if this is related but I also changed my brake pads few days ago and the next day I got a message saying brake failure stop safely engine service required but the brakes works fine and no issues with the engine if any one had any similar issues please advice I really hope its not the transmission again
thank you
Old Mar 23, 2016 | 12:42 AM
crane550's Avatar
These cars are notorious for transmission problems. Sounds like the transmission might be slipping again. Could you please clarify- does the car rev up but just not move? Also if you restart it does the car move for a bit and then die out again?
Smell the dipstick to the transmission. Does it smell burnt?
Alex
Old Mar 23, 2016 | 01:19 AM
skodamk's Avatar
Alex
The engine run perfectly but it's almost like the car is always on natural no matter what position the shifter is on the car doesn't move you could also push the car forward or backward while the shifter is on drive or reverse only the park is functioning right u can't push it and u can take the key out when the old transmission went bad it was slipping for a while on the third gear and the second but I was still able to drive it for 1200 miles from Miami to nj before I got it fixed today it didn't slip at all it just stopped working those cars don't have dipstick but there was no burnt smell
Old Mar 23, 2016 | 06:32 AM
ES6T's Avatar
The V8 isn't nearly as prone to trans problems as the T6.
You need the codes read. That goes for any warning message.
Old Mar 23, 2016 | 09:00 AM
skodamk's Avatar
That's what I thought before buying it I can't find much information about the warning messages and There is no DTC codes coming up !
Old Mar 23, 2016 | 12:08 PM
ES6T's Avatar
There are codes. You're probably using a generic scanner.
Old Mar 23, 2016 | 01:03 PM
skodamk's Avatar
There was no enhanced codes but I was able to get the car to drive by resetting it I disconnected the battery and it rest I think that the car was in limp mode not sure why but that's gonna be my next thing to find out why was it in limp mode but now it seems to drive fine
Old Mar 23, 2016 | 04:17 PM
ES6T's Avatar
If those messages were on, there were codes. Without them, you can't do much with any certainty.
Old Mar 23, 2016 | 08:05 PM
masscomguru's Avatar
If the transmission replacement was recent, it could just be a bad connector somewhere. check al of the connections to and from the transmission.
jordank
Dec 29, 2022 02:20 PM
Nigel Adelaide
Oct 12, 2013 07:16 PM
rlewinter
Oct 7, 2010 02:17 PM
chrissygm
Sep 30, 2008 05:53 PM
paulbelanger
Aug 9, 2006 10:13 PM
