Identification of Random Sensor - Please Help!
Old Jan 2, 2018 | 11:33 PM
Linestarboard's Avatar
Unhappy Identification of Random Sensor - Please Help!
I've got a sensor/connector which was sitting just forward of the ECU on my 2007 3.2L XC90 which wasn't connected to anything? I think it might be an optical crash, or ambient temp sensor (randomly different, I know)? It's got P/N: 9456721 on it, which is listed as a Cover in the ECU Harness, but does not identify the actual sensor (item 18 in attached link https://parts.volvocarsofphoenix.com...2/9456721.html). Please help, I've currently got it sitting near the intake grill to get ambient air temp (if that's what it's for...).
My wife lost all of her coolant in a heatwave here, and I've got a check engine light. I've tracked down several problems as a result. I've proven the electrical radiator fan has a burnt out contact on it, and also found a torn PCV valve (and consequently just replaced both), so I'm not sure which one would have been causing this engine light, or if it's this sensor (or maybe it's all of them?). I normally like to only change one thing at once to verify a problem's fixed, but I found all of this stuff broken, so needed to change it all.
I haven't started the engine yet, as I really want to know what this sensor is.
Thanks for any help you can provide. P/N: 9456721. Note, it's both halves of the connector in one assembly.
Note the frame clip on the bottom of connector
Old Jan 4, 2018 | 09:54 PM
ES6T's Avatar
That isn't a sensor. That is an unused electrical connector with a dummy plug in it to keep junk out of it.
scirocco
2001-2013 model year V70
Jul 29, 2016 10:33 AM
TheGageinator
Jun 4, 2015 08:01 AM
cljimmy72
Dec 15, 2014 04:24 AM
xjguy
Dec 11, 2010 05:15 PM
trueimport
Feb 13, 2010 08:59 PM
