Mystery part identification
This part fell from the driver side while I was replacing the evaporator. I think it might belong to the steering column component but I have not been able to find out where it goes. No one has been able to help. Help...I cannot continue putting my car back together until I put this part back where it came from.
It is stamped VOLVO and WITTE(makers I think). The numbers on it are 08659081 A and the Pat. Nr. is 0176663.
This is an animation I found of the part.
I think the part is for filling gaps and providing compensation for areas where the 2 joining parts should remain parallel.
Thank you so much ES6T for the quick response. And for the record...you are absolutely correct in determining where this "mystery" part belongs. I went out briefly and looked at both sides of the member and I could see the right side "mystery" part is there and the driver(left) side "mystery" part in fact is missing. I have spent numerous hours hunting and being frustrated about this part but now I am confident that I can return it and finish my work on the car due to your excellent help. Thanks again and once I get in place for photos I will snap a couple and provide them as evidence for all to see. Semper Fidelis!
This part fell from the driver side while I was replacing the evaporator. I think it might belong to the steering column component but I have not been able to find out where it goes. No one has been able to help. Help...I cannot continue putting my car back together until I put this part back where it came from. https://youtu.be/2y3N6b9SD_o
This is an animation I found of the part. https://youtu.be/JyKiM5fd-ns
Need to replace my XC90 evaporator as well. Can you please share short procedure so and precautions in doing so?
arjukai26@gmail.com
TIA
Ron.
BMWgiant
03-21-2012 01:03 PM
