Need help! I'm an idiot. 03 XC90
Old Sep 8, 2010 | 12:43 PM
scottp's Avatar
Exclamation Need help! I'm an idiot. 03 XC90
Hello all! I was trying to get the radio out of my 03 XC90. I popped the trim off around the switches next to the cvigarette lighter and then was popping off the pannel around the climate controls woerking my way up. I realized that that was not the correct way because it was getting difficult. I put everything back together, but now THERE ARE LIGHTS NOT WORKING BEHIND SOME BUTTIONS! Does anyone have any suggestions or a diagram of the entire unit blown apart? Any help is very much appreciated!
Old Oct 28, 2010 | 09:11 PM
anichin's Avatar
I have XC90 2004 and I am having the same problem. I am stuck at removing the climate control panel. Something is holding it from the top. Can anyone help?
There are 6 screws that I removed shown on the picture but still no luck.
Old Oct 28, 2010 | 09:25 PM
I have not had one out in a while. But if I remember correctly they are like the S80 and S60. There is metal tabs sticking out from the bottom of the radio area. The climate module slides into under the radio. You need to tip the climate module slightly out on the bottom then pull it straight out. It is a major Pita sometimes.
Old Oct 31, 2010 | 10:13 PM
Scott_Mick's Avatar
Default 6 screws and clips
You found the required screws to swing the whloe unit out from the bottom. The lip at the top holds it into the dash. There are spring clips around it to keep it tight.
You can get more access to the top of the radio cluster by removing the vents, but they have self-locking tabs at teh top of the vent opening.
Attached Thumbnails Need help! I'm an idiot. 03 XC90-picture-086sm.jpg   Need help! I'm an idiot. 03 XC90-picture-087sm.jpg
ontopcop
Jul 9, 2007 01:01 AM
WilliamD1979
May 15, 2007 08:31 PM
S70driver
May 25, 2006 01:00 AM
Esercitare
May 24, 2006 08:36 PM
Bummer
Jun 3, 2005 02:26 PM
