Need a key for 2010 XC90
Old Oct 17, 2022 | 09:09 PM
crazyresidual's Avatar
Default Need a key for 2010 XC90
Somehow my son managed to destroy the key for our 2010 XC90. I think the steering wheel was locked and he went to turn the key and he forced it and it busted the key. I am needing a whole new key for the car. What is the cheapest way to fix this issue?
Thanks
Old Oct 17, 2022 | 09:51 PM
Exactly what is broken? Do you have the switchblade key and that end is damaged?
There will be no cheap fix. The key portion has a chip in it that is required for the immobilizer to turn off to allow the car to start.
With the swithblade style key the remote is detachable - and hopefully if not damaged can be reused.
Need just a few more details -
Any replacement key will need to come from the dealer - the reason is - any key requires a software download using VIDA to tell the car to accept the signal from the new key. Certainly there are shops or individuals that have a VIDA subscription. In fact you could do this yourself with a Dice unit and a Vida subscription -
Easiest solution - If the key portion of a switchblade key is damaged - order a new key (that half of the remote) precut from your preferred dealer using the VIN. When it arrives and sucessfully operates the door and ignition lock - have them "program" your car to accept the signal from the new key. Simple process for maybe $200 or so total. Then attach the new key to your exisitng remote.
dago83
Jan 29, 2022 02:57 PM
William Carter
Dec 14, 2020 02:56 PM
Steve Culp
May 9, 2016 11:17 AM
04XC90T6AWD
Mar 15, 2011 09:59 PM
gstone
Oct 17, 2009 01:02 PM
