New XC Owner with minor (I hope) problems
Old Dec 29, 2014 | 10:01 AM
rsaavedra2's Avatar
Default New XC Owner with minor (I hope) problems
Hi all,
I just purchased a 2008 XC90 V8 with about 55,000 miles on it and I have a couple of minor issues:
1. Putting it into drive: When I start the car, I need to wait between 10 to 15 seconds before it will let me take it out of the 'park' position. It's parked on a flat driveway.
2. Shutting down the car: When I turn the car off, it won't let me go past the I position. This time I have to wait about 5 seconds, then it will let me put the key in the 0 position and take the key out.
This is my first Volvo, so I'm not sure if this is normal and I need to be patient when the car is starting up / shutting down, or if something is wrong.
Any help is appreciated, I searched the threads for similar issues but didn't see anything, if you know of an existing thread that explains this, please paste the link
Ruben
Old Dec 30, 2014 | 09:05 AM
tony1963's Avatar
Sounds to me like the shifter button is sticking. Common problem in Volvos. You can't remove the key until the shifter button fully releases.
Have someone remove shift **** and lubricate. Problem will be solved.
Old Dec 30, 2014 | 09:56 AM
rsaavedra2's Avatar
Problem solved! I ended up finding this thread and followed the advice:
https://volvoforums.com/forum/volvo-...t-shift-24908/
Sure enough, once I took the center counsel off, I could see everything in the shifter moving slowly. I used some cleaner and lubricant and now it works great!
wb2alta
Feb 6, 2015 06:12 PM
BIGJake111
Jun 25, 2014 10:11 PM
alCanister
Jun 17, 2012 11:02 AM
740 Volvo
Aug 9, 2005 11:32 PM
95Volvo940
Oct 18, 2004 09:11 PM
