No reverse on XC90
Old Jan 25, 2022 | 08:36 PM
Kabueno's Avatar
Default No reverse on XC90
Hello, i have a XC90 from 2007 and 149 000 miles. Two weeks ago I was unable to shift on reverse. I mean I was able to put the reverse but nothing was happening when shifting. However the car still drivable for the other shifts.
One mechanical thinks we need to change the transmission fluid.
Another one thinks this is probably the shifter.
Any idea ?
Thank you.
Old Jan 25, 2022 | 08:56 PM
What engine? 5,6, or 8 cyl?
(and Trans fluid change won't fix it, and probably not the shifter!)
Someone (in the right hands) should be able to use a compatible scan tool to determine what signals are being sent to the solenoids in the transmission, no matter which one you have.
Old Jan 25, 2022 | 11:03 PM
Kabueno's Avatar
6 cylinder, 3,2 liter Sport Utility 4D
Old Feb 3, 2022 | 10:28 PM
Kabueno's Avatar
Default Problem solved Xc90 no reverse
Problem solved apparently !!!
The mechanical was not sure but tried to change the transmission fluids and it worked. It has been one week and no more issues for the moment.
Hope it can help somebody else cause it costed 450 dollars instead of 7700 (a mechanical wanted to replace all the transmission...
shadow13
Jan 4, 2023 09:33 PM
oliver1064
Aug 9, 2011 04:15 PM
k
Dec 22, 2009 05:11 AM
hrtrhb
Mar 26, 2009 07:52 PM
jessica740turbowagon
Sep 9, 2007 08:33 AM
