Thinking about buying an xc90
Old Apr 25, 2017 | 10:41 AM
willsern's Avatar
Default Thinking about buying an xc90
Hey I'm looking to buy an xc90 maybe 03-09 whatever I can find a good deal on or something that needs work, so I can get it cheaper. Is it a good idea though with all these transmission problems I'm hearing about? I have an s60r I'm selling now and looking for another Volvo. I replaced the head on it so I don't mind doing some work and I will do all the work. Is it only the t6 that has transmission problems?
What do you guys think of this one? https://delaware.craigslist.org/cto/6096228723.html
Thanks for the help I really appreciate it.
Old May 3, 2017 | 09:27 PM
Gardel's Avatar
Stay away from the T6, it had tranny problems. I had a 2006 2.5 and it had an Asian-Warner tranny that at 125k was rock solid. 2007 and newer have pretty good transmissions too. The T6 and early V8's were the problem. Try to buy one that needs nothing.
Old May 4, 2017 | 09:26 AM
firebirdparts's Avatar
Just get a T5.
That said, as I am sure you know, there is not a lot of complication that could be added above what an XC90 has. If you eliminate the T6 with its transmission, you can still have CEU failure, water leaking into the yaw sensor, AWD shutdown, etc. etc. etc. It's a really complex machine.
Old May 11, 2017 | 07:20 PM
arfstrom's Avatar
Not to mention the normal maintenance of timing belt, PCV maintenance, engine mounts, wheel bearings, front strut noises, (sway bar)
bailer123
Nov 9, 2010 08:17 PM
Rocketfish
May 1, 2010 11:43 PM
dbackbmx3
Jun 29, 2009 02:11 PM
jakery7
Jan 11, 2009 08:01 PM
dorseto
Aug 25, 2007 01:21 PM
