Tire recommendation for 2018 XC90
Old Apr 18, 2020 | 11:28 AM
davidtirado's Avatar
Default Tire recommendation for 2018 XC90
Hi,
I'm in need for new tires for my 2018 XC90. Does anyone have recommendations for best driving tires with minimal noise, the tires I have now seem to be a bit loud for the vehicle.
Thank you.
Old Apr 18, 2020 | 01:34 PM
best thing to do is use a tire site with ratings and customer reviews. Tirerack.com has some very good content and ratings on decision factors like noise, wear, wet/dry handling. Also, make sure you keep your car properly aligned. A bad alignment can cause "cupping" on tires which will make any tire noisy. You should get your car's alignment checked at least 2x a year. If you live in an area with snow, you may want to consider running winter tires and summer tires vs all seasons. AWD helps your car go - winter tires help it stop.
Old Apr 18, 2020 | 02:10 PM
Jawad's Avatar
Hello,
does any run flat tire fit to the xc90 2016 ?
Cheers
Old Apr 18, 2020 | 02:14 PM
Tirerack and similar sites would tell you that. Besides you didn't mention what size wheel your XC has... Also, before considering run flats, read up on issues with repairing run flats.
Old Apr 18, 2020 | 03:55 PM
Jawad's Avatar
thank you, i have 20 "wheels, repair worries are not a problem for me. In the worst case I would replace the tire. My job requires to be absolutely mobile.
Does it exist in Michelin?
Old Apr 18, 2020 | 05:23 PM
Did you go to tirerack.com and plug in your info?
Spoiler alert - you can chose between Conti, Pirelli and Bridgestone.
Mmong
May 1, 2019 08:56 AM
mpgarrity
Nov 15, 2013 08:28 PM
riverwhy1
Nov 16, 2010 03:04 PM
jec_vf
Dec 12, 2008 07:53 AM
