Vibration when ac is on
Old May 27, 2015 | 04:52 PM
allenot1's Avatar
Default Vibration when ac is on
I'm getting this vibration inside the car only when the ac is on. What could be the problem? When I turn off the ac, the vibration disappears.
Old May 27, 2015 | 10:34 PM
damien360's Avatar
Compressor clutch.
Old May 27, 2015 | 11:28 PM
any noises? take a look at the compressor when on/off how is it vibrating and does it look like the mounting is proper? Could be the compressor, the clutch or that the idler pulley has a bad bearing as well - you'd need to remove the belt to turn the wheel by hand to check that. Anything else under the hood that appears to be vibrating or resonating?
Old May 28, 2015 | 03:59 PM
allenot1's Avatar
I'll check the idler pulley tonight. So what am I looking for once I turn it by hand?
Old May 29, 2015 | 06:11 AM
schumicat's Avatar
see if any cooling fan blades are missing a piece (on many cars ac turns fan on, I think xc90 is one)
ocean238
Apr 17, 2008 06:20 PM
JimKW
Jun 14, 2005 06:38 PM
CFGVolvo850
May 18, 2005 10:59 AM
alecw81
Mar 7, 2005 10:47 PM
Macgregorguy
Dec 19, 2004 03:48 PM
