XC90 2.5T 2 second metallic screech from belt area on start up
Old Aug 4, 2014 | 02:41 PM
christopherandrews1989's Avatar
Default XC90 2.5T 2 second metallic screech from belt area on start up
hello everyone was just looking for some help with my xc 90 with duel VVT
ive just replaced the head gasket and re-lapped valves etc basic head rebuild
ive aligned the crank pulley and timing marks on the cam shaft cranks to TDC
the cam pulleys are 100% clockwise in accordance to TDC
ive aligned the rear of the cam shaft pulleys so that they are 100% horizontal
ive replaced the water pump, timing belt and AUX belt and all pulleys & tensioners
when i turn the engine over there is a noise for a split second that sounds like
metal on metal screech followed by a short hiss , this noise only happens on start up can anyone tell me what this is???
also the engine is not reaching operating temperature even when its been sitting for 10 mins the temp gauge is 1 bar below the mid line ?? ive replaced the thermostat recently also
any ideas would be appreciated
thanks for your time
Chris
newmex999
Sep 10, 2013 09:27 PM
V70-T5
Jun 20, 2010 06:58 AM
Kivstev
Oct 7, 2009 05:12 PM
jmp29
Jun 16, 2009 06:36 PM
mauriciogalvao
Nov 28, 2008 06:12 PM
