XC90 Headlight issues
Old Aug 5, 2022 | 06:23 PM
bill4jesus's Avatar
Default XC90 Headlight issues
XC90
Hi, everyone. I have a 2011 XC90 with 142K miles on it. Two days ago, the drivers side headlight assembly went dark on me. I have replaced the original headlights with LED's about six months ago and they have been performing well. The running lights work on both sides, but as soon as it gets dark both low and high beam lights go out on the driver's side. If I flash high beams, the work correctly on the passanger side but don't function on the driver's side. I do have "active beams". I have checked the fuses, but they seem to be ok. The reason I believe that this is not a simple issue is because the driving lights (high beam on low) works but goes out immediately upon light falling. The low beam H1 headlight drivers side flashed momentarily when activating the high beams, but will not stay on. Has anybody had this issue before?
Thanks in advance for any input.
Old Aug 6, 2022 | 10:52 AM
Your headlamps are set to automatically come on when dark. The inner daytime running lamp going off when it is dark is normal operation.
The problem is "I have replaced the original headlights with LED's "
Put your original bulbs back in and see what happens.
enjuaguese
Jan 1, 2016 04:13 PM
mcnallystep98
May 8, 2013 10:54 AM
wlandymore
Mar 2, 2013 08:43 AM
chrisxc90t
Jul 6, 2012 12:32 AM
dljdad
Jan 4, 2010 05:39 PM
