XC90 ICM module repair/replacement question
Old Jan 19, 2012 | 06:23 PM
  #21
Carson's Avatar
Originally Posted by Heaviside
I bought a salvaged one from eBay seller volvopartsonly for $247 plus $12 shipping. I installed it myself today, and it is working like a champ!
This is part of a larger saga that I am describing in a separate thread.
If you want to go the used route, be careful to get the right one. There are at least two varieties of ICM. Mine was the so-called matrix display that works with the premium sound. Also, the installation is fairly straight forward but there are a couple of tricks. Let me know if you need advice.
At least in my case, no programming was needed--plug and play.
Dan
My ICM is out too. Everything works fine except the screen is blank. Your suggestion to buy from volvopartsonly sounds like a good path to take. How do I determine the part number?
Thanks,
Not a very mechanical person,
Carson
Old Feb 25, 2012 | 06:51 AM
  #22
michigan66's Avatar
Default replacement ICM module not working
Hi,
I have bought a replacement ICM module (matrix) what my old one was as well.
it was easy to remove the unit and get the new hardeware in, but once installed, the screen is still blank. no matter, which button I push, nothing happens.
the stickers on the old and the new ICM modules have different numbers on it. see the attached old and new pictures.
any idea, how I can proceed with the new unit to get it working?
your help is very much appreciated.
thank you.
Attached Thumbnails XC90 ICM module repair/replacement question-old_icm_1.jpg   XC90 ICM module repair/replacement question-old_icm_2.jpg   XC90 ICM module repair/replacement question-new_icm_1.jpg   XC90 ICM module repair/replacement question-new_icm_2.jpg
Old Feb 29, 2012 | 01:54 PM
  #23
cbotd's Avatar
Default Second Hand ICM Fix
Well after many attempts at a quick and inexpensive repair I took the XC90 to the dealer for an official diagnosis. They went through many of the same things I had already done and told me the ICM needed to be replaced. The cost... $1,300 USD.
I took to the Interwebs to find a better way. Forum posts and eBay took me to VolvoPartsOnly. They have used ICMs for various amounts (most between $250 and $300 USD). I ordered one post haste. When it arrived I plugged it in and got nothing. No audio, no lights, nada. I took it to the dealer for a software flash hoping that would bring it to life... nothing. Dealer said the ICM was not recognized because it did not match my VIN.
The dealer did call Volvo USA and got me the four part numbers that will work in my XC90. I called Patrick at VolvoPartsOnly and he gladly swapped the ICM I bought with one that matched one of the Part Numbers I got from the dealer. In fact, he gave me the exact part number I pulled from my SUV. It was plug and play and I now have a screen and operational ICM for 1/4 of the cost. Patrick even sent me a pre paid shipping label to return the other ICM that didn't work.
Not a big fan of a $300 fix for old equipment that still doesn't have the nice features of a modern unit (aux input, SAT, HD Radio, etc) but I sure like the price better than $1,300 from the dealer. I may have the software flashed to match my vehicle for $93 just to be safe. Glad to have a working ICM and hope to get some trouble free miles out of this one.
Old Feb 29, 2012 | 01:58 PM
  #24
cbotd's Avatar
Default Which is your original number
You'll need a part number that matches your original or one that will work with your VIN. I had an origianl PN30679179 and can supply you with the corresponding part numbers the dealer got from Volvo if you would like. Unfortunately none match the other number shown in your pics.
Originally Posted by michigan66
Hi,
thank you.
Old Feb 29, 2012 | 02:01 PM
  #25
cbotd's Avatar
Default Part number on back of ICM/Display Unit
The part number is found on the back of the Radio Display unit. It will require removal of the unit. In all honesty, removing the unit is fairly easy. I have done it in less than 5 minutes once I knew what to do. Not a lot involved, just some basic steps.
Thanks,
Carson
Old Mar 3, 2020 | 08:06 PM
  #26
Amanda Brosnan's Avatar
Dan
hey dan what were the tricks you used? I bought a radio off eBay (same exact model number as the old one) I was getting sound before the replacement but now I get absolutely nothing, swapped them back and still get nothing. Fuses were fine.
Old Dec 11, 2020 | 02:14 PM
  #27
Lescurd's Avatar
Default Re icm
I also bought a icm which was exact same model number off ebay from a real good seller I put it in my car and it still only displays the premium sound message on the screen for about 5 seconds and then goes out like my original one does did you ever figure yours out and get it to work I'm thinking maybe the amp or the radio receiver in the rear of car is no good
Old Aug 29, 2021 | 10:41 AM
  #28
Elvis's Avatar
hi cbodt, I have the same part number 30679179. Tried to swap it with one from the yunkyard that luckily had the same PN. But didn't work screen didn't even turn on. Could you please tell which other part number will be compatible? Thanks.
Old Feb 15, 2022 | 01:22 PM
  #29
Veetwinboy's Avatar
Default Any update on stereo not working?
Hi, I just wondered if you managed to sort the radio issue, I’ve just bought a 2005 XC90 with the same symptoms you had, premium sound showing for a few seconds only!!
would be keen to know what you did, thanks
Paul.
Old Aug 4, 2022 | 12:02 PM
  #30
grghost's Avatar
I know this is a long time since orig post, but our 2005 volvo xc90 radio and back up sensor failed, after having our shocks and struts replaced. Prior to that no issues, could be coincidental, or could have been initiated by shop repair, doesn't matter. Shop disclaiming any liability. Now we need a new ICM. Seems like they are running between $900 and 1200 new. Found a place online that repairs your ICM for $375, thus avoiding a trip to dealer for reprogramming. Has anyone gone this route, and was it successful? The place is called Hi Tech in Van Nuys, CA. FYI, the computer has not been updated probably since 2010. Reno, NV dealer quotes cost just to update computer to be $2000! (that would not be including reprogramming for new ICM. Would appreciate any advice/suggestions.
elvato1980
May 31, 2013 12:21 PM
IainUK
May 23, 2013 10:48 AM
msweeney
2001-2013 model year XC70
Jan 27, 2013 09:48 PM
johnie1982
Oct 6, 2010 12:32 PM
icyboarder
Dec 11, 2009 01:19 PM
