XC90 loud grinding noise at low speed
Old Dec 23, 2018 | 12:05 PM
Chibuike.a's Avatar
Default XC90 loud grinding noise at low speed
I recently bought a 2008 XC90 3.2 AWD. Everything seems okay except it makes a loud grinding noise when on low speed (below 20mph). No noise when I go on high speed. I changed break pads but it didn't stop the grinding noise.
Any one experienced this before and how was it fixed?
Old Dec 23, 2018 | 01:53 PM
does it change pitch when turning left or right? since it seems to be road speed related, the likely causes are either a wheel bearing or an axle bearing/cv joint. Check if the axle boots are in good shape but my guess is its a wheel bearing.
Old Jan 12, 2019 | 03:02 PM
Franksauto's Avatar
I'm having the same or similar issue. It's not the brakes, axle shaft or a wheel bearing. Its a weird more rattling than grinding noise at low speed start off. goes away on the highway. Sounds like its coming from the mid to right front.
ses_volvo
Dec 24, 2014 11:53 AM
yaan
Aug 21, 2013 08:30 AM
EMD886
Oct 19, 2012 10:13 PM
mcollard
Jan 15, 2010 06:25 PM
mgacarnut
May 8, 2009 11:19 PM
