Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
850 left corner headlight popped out
Old Aug 15, 2008 | 05:28 PM
atl_volvo's Avatar
Default 850 left corner headlight popped out
I took my poor baby over a speed bump a little too hard and my left side corner light popped out. The wiring wasn't disconnected so the signal still works but the casing is dangling on my fender.
I looked at the right side corner light and see there is a spring/coil that connects the casing. On the left lens case the plastic broke off and the spring is gone. None of the local autopart stores carry the casing so I gotta order online. Soo question is if I buy this online will the coil/spring come with the lens casing?
Old Aug 15, 2008 | 07:15 PM
Default RE: 850 left corner headlight popped out
Some do some don't. Check with the company.
Old Aug 22, 2008 | 01:59 AM
khooper's Avatar
on the top corner of the headlight facing the fender. there is a screw. that screw keeps the corner light from falling off. so all you need to do is unscrew that one screw and you just pop the light right off. its held on by a ball cup thing that is connected to the headlight. it takes like 2 minutes to take off and put back on. its really that easy.
__________________________
Check out: Discount Volvo Parts
Old Aug 22, 2008 | 08:02 AM
ORIGINAL: khooper
There is no screw at all that holds the corner lights on. It is only held in by a spring.
E60M5
Nov 30, 2012 04:26 PM
Rswitz
Oct 14, 2012 10:31 AM
MC92
May 25, 2011 11:08 AM
n3cr0
Nov 20, 2007 12:21 PM
keylargokeith
Jan 2, 2007 08:57 PM
