Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
bumper
Old May 27, 2009 | 09:30 PM
paparoach's Avatar
Default bumper
Do you need to remove the bumper to replace the driver's side headlight assembly on the 1998 Volvo S70?
_________________
Flex Plate + Tear Drops On My Car - Jake Erkens
Old May 28, 2009 | 06:26 PM
No you do not. Remove the corner light then the headlight.
Old May 28, 2009 | 07:00 PM
S70driver's Avatar
FYI there is a tab on the inside of the fender wall on the turn signal. It is fragile in a way that you couldn't believe. Be very careful when depressing it and removing the turn signal.
Then to remove the headlight assembly remove the three 10mm screws that are on the back of the housing. It will pull right out then.
Old May 30, 2009 | 10:19 PM
rallyracer's Avatar
you may have to slightly pull up on the assembly and push down on the edge of the bumper to clear. unfortunately, the plastic on these cars seems to deteriorate fast, so you may end up breaking several fasteners before figuring out how something is disassembled.
shadowlord
Apr 8, 2008 09:16 PM
sghokie
Jun 30, 2005 12:17 PM
Zarkos13
Feb 18, 2005 01:57 AM
jamestolson
Jun 10, 2004 12:23 PM
goofybut
Apr 20, 2004 02:21 PM
