Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
License Plate Mounting Bracket
Old Aug 10, 2009 | 10:54 PM
Starbuck1975's Avatar
Default License Plate Mounting Bracket
Recently purchased an XC60, and want to place license plate frames over my license plates.
Problem is that most license plate frames only have two mounting holes along the top, but the standard Volvo license plate mounting bracket has four screws welded into the mounting bracket frame.
Digging around, I found the part number for the standard Volvo license plate mounting bracket:
9154456 License Plate Retainer Bracket
Here is what it looks like:
http://www.ipdusa.com/version.asp?st...272&V_ID=12421
I have a few options:
- Remove two of the welded screws on the License Plate Retainer Bracket that came standard OR
- Drill holes in the license plate frames
Was hoping there might be a third option. A mounting bracket, either universal or unique to Volvo, that only has a two top screw configuration.
Anyone encounter a similar problem, and found a solution?
Old Aug 11, 2009 | 12:40 AM
TIPSP's Avatar
Got Boost?
I would drill the frame.
What frame is it?
Old Aug 11, 2009 | 10:17 AM
Alumni frames. Reluctant to drill holes, as the bolts will obscure most of the lettering, which kind of defeats the purpose of the frames.
PMAN65
Apr 15, 2015 05:38 AM
tylerdurden4543
Jan 26, 2013 03:40 PM
Philthisup
Jul 4, 2011 10:16 PM
tlarvenz
Feb 1, 2007 10:45 PM
