Where is my oil leak coming from!!
Old Nov 16, 2009 | 09:00 PM
  #21
Originally Posted by windtamer
It took me around 1 hour to replace. I bought the cam locking tool from iPd. Just make sure you get all the timing marks lined up before you take off the timing belt and use a marking pin and mark the cam and gear BEFORE you loosen the 3 bolts that hold the gear to the cam. I used my pocket knife to pop the seals out. The cam locking tool will help you to make sure the cam gears are in timing when you put the cam gears and timing belt back on. I used a table vice to press the tensioner and a small drill bit to hold it in place when I reinstalled it.
I guess I'll have to take this into consideration. Once I get the backside of the timing belt cover off so I can see behind it and know more about the situation I'll look into this. I'd rather do it now while the motor is apart and not in the car if it needs to be done.
volvoQ's
Jan 30, 2020 06:03 AM
jeff71
Oct 20, 2014 11:01 PM
davepays
Dec 19, 2009 06:56 PM
200bucks
Oct 19, 2008 12:53 PM
nationm
Feb 12, 2006 10:09 PM
