Blower Motor Question
Old Jul 25, 2009 | 06:11 PM
Keith Tobberman's Avatar
Default Blower Motor Question
Hey,
My 1995 Volvo 850 Turbo has a broken blower motor I think. It does not shoot air unless I am going fast enough for it to come throught the vents. I am assuming this is a blower motor failure. If so, how much money will this job be for parts and labor? I believe the shops around here charge $50 an hour or so.
-Thanks
Old Jul 25, 2009 | 07:08 PM
Ozark Lee's Avatar
I'm not sure what the book time is but the blower takes me about an hour in the driveway if I were to R&R it. The blower assembly runs around $160.00 I think for the part from FCP - a shop will mark it up and it will cost you more than that.
If the blower totally seized then chances are it also took out the blower resistor or the power stage depending on which type of climate unit you have.
It is actually quite easy to fix yourself, I did a writeup here:
http://www.matthewsvolvosite.com/for...hp?f=1&t=19322
...Lee
Old Jul 25, 2009 | 11:45 PM
I am not very mechanically inclined, so, if done at a shop, am I looking at over $500 US all together?
-Thanks
Old Jul 26, 2009 | 01:41 PM
Saleen9090's Avatar
http://www.ipdusa.com/Volvo-850/Elec...-154-174-1905/
Here is a non-OEM one for $136. It is probably reliable enough to buy and save money.
It is not hard at all to install. It is just a matter of dismantling the glovebox a little. After that it is just a plug/unplug scenario.
WHAT REALLY SUCKS is that about two weeks ago I had an extra perfectly good working blower motor that I got rid of because I didn't think I would ever need it again. I would have sold it for like $10 +shipping. Just bad luck on timing I guess.
A volvo dealership would probably charge $50/hour which would be about an hour job for them.
Old Jul 26, 2009 | 07:33 PM
JimKW's Avatar
A Dealer at $50 and hour. I doubt it. More like $80 minimum.
Old Jul 26, 2009 | 08:17 PM
Many stealers are as high as $130 per hour. They figure if you are using them in this economy you have no other option. Any way it goes, they will tell you the labor cost of doing the job over the phone before you come in. They have the labor hour estimate for every job. They they will likely NOT accept your part so you can expect to pay their part cost.
That is another entire subject. Some dealers charge more than others on parts. My stealer charges 50% more for parts that I get from the stealer in Charlotte. So, if I have to get it from a stealer, I call and order from the one in Charlotte. LOL
Old Jul 26, 2009 | 09:16 PM
blackbrick's Avatar
It looks easy job to do if you folow Ozarks writeup.
Here is link to buy just motor and use old fan cage & housing it is $65 :
http://www.partsgeek.com/catalog/199...wer_motor.html
Old Jul 26, 2009 | 11:37 PM
Thanks for the replies. How many hours would it take for a dealer to do it on average?
-Thanks
Old Jul 27, 2009 | 12:13 AM
850tony's Avatar
call and ask
Old Aug 9, 2009 | 07:57 PM
Hey,
I noticed that my lighter outlet in the front does not work. I believe there used to be light showing in it, and now there is no light and when I plug stuff in it, it does not work.....could this be related? Is there a fuse that controls both?? Also, in my instrument cluster, the time is all that shows and there is no access to gas mileage, trip odo, temp, etc.? I am wondering if there is some kind of connection to this all...no pun intended.
-Thanks
Old Aug 10, 2009 | 07:26 AM
I'm sorry to say but if you don't know how to check your fuses, you need to get a friend that can do that for you FAST. Or drive the thing to a machanic quick.
As for the lighter, there is a light that can be blown out there. Or the thing may have blown a fuse, not sure which. As stated above, let someone check your fuses and get the thing fixed. It's hot all over the country and I can't imagine you driving with no AC.
Old Aug 11, 2009 | 04:35 PM
Hey,
I know how to check my fuses but, I was wondering if if could have been another electrical issue. I have not been driving it much, I use my motorcycle most of the time, haha.
-Thanks
Old Aug 14, 2009 | 12:02 PM
Saleen9090's Avatar
As for the cigarrette ligter:
Check underneath there. The electricity supplied to the bulb and to the actual lighter itself are different wirings. It is a coincidence that both don't work.
As for the instrument cluster:
Does it say DISC or nothing at all?
It may be a disconnection in the back of the cluster or the switch to change displays may simply be disconnected in back.
xsadie19
Nov 1, 2012 01:41 PM
equate975
Mar 14, 2009 10:51 AM
afirestine
Dec 13, 2007 08:33 AM
Evo 850
Nov 24, 2007 05:25 PM
TLC_Lover
Sep 9, 2007 05:24 AM
