vent box
Old Oct 9, 2009 | 06:58 PM
Spike555's Avatar
Default vent box
My wifes '95 turbo is doing this exact same thing.
https://volvoforums.com/forum/new-members-area-4/94-volvo-850-turbo-6771/
The links for the pics are no longer working.
Can you guys help me find this vent box so that I can clean it?
Old Oct 9, 2009 | 08:46 PM
Somthngfrce's Avatar
You have to remove the exhaust manifold to expose the vent box. Normally you just replace that along with associated plumbing instead of cleaning. Do a search for PCV on the 850 forum and there's a "How to"..
Old Oct 10, 2009 | 09:20 AM
JPN's Avatar
JPN
Great write-up:
http://www.lakesidedp.com/uploadpics/pcv/
JPN
Old Oct 10, 2009 | 03:44 PM
Spike555's Avatar
Yeah I found that write up before I posted.
I have by-passed it for now until I can replace the PCV tubing.
That should stop the smoking.
Thanks guys.
Old Oct 11, 2009 | 08:35 AM
JPN's Avatar
JPN
I hope it goes well and eliminates the smoke issue.
JPN
Old Oct 11, 2009 | 06:14 PM
Spike555's Avatar
The smoke issue is gone.
I removed the PCV from the top of the valve cover and ran a vacuum line under the trim piece on top of the engine down the front of the engine and dump it out under the car.
Then I took another vacuum line and connected it to the now free laying piece of PCV tubing that was connected to the top of the engine and ran it down the back side of the engine and dumping it out under the car.
I made sure that both vacuum lines that I used would not be in the way of anything, like the cooling fan or the exhaust.
Does it look pretty?
No.
But now there is no big cloud of smoke when you are sitting in the drive through.
eyukins
Dec 19, 2008 07:18 AM
silencecom
Jun 22, 2008 06:30 AM
JPizano23
Feb 5, 2007 08:54 PM
98v70
Jan 26, 2007 10:24 PM
JPizano23
Nov 22, 2006 08:27 PM
