Blower Motor won't shut off, Resistor blown?
Old Nov 16, 2009 | 10:01 AM
vvod's Avatar
Default Blower Motor won't shut off, Resistor blown?
Hi everyone.
My Blower motor runs at the highest speed regardless of where I have the control setting at. The only way to shut if off is to pull the fuse.
I looked at my Haynes manual it says to check the OBD codes so I bought a $50 reader but no codes relating to the blower came up.
I've been told by the parts counter guy that its the resistor but I've also been told there are two.
i. How do I tell which one is gone?
ii. Where are they located?
Winter is approaching soon wondering if you guys can help me out before I begin to freeze!!
Old Nov 16, 2009 | 01:28 PM
fcpgroton's Avatar
Former Sponsor
So when the fan is in the off position, the fan is still running? If that is the case, there is an issue with your ECC.
As for the codes, you need a special Volvo code reader to reader the ECC codes. The only codes you can read with an OTC scanner are the fuel codes.
Old Nov 17, 2009 | 08:39 AM
vvod's Avatar
When the fan control dial is in the off position the fan remains running at the highest speed.
Do you know what part of the ECC I should be looking at?
Old Nov 17, 2009 | 09:15 AM
fcpgroton's Avatar
Former Sponsor
The ECC is one whole unit. What I would do is remove it with the connectors still connected and see if power is getting through the fan control switch even when it is off, then you will need to replace the whole ECC.
Old Nov 17, 2009 | 12:17 PM
TCP Productions's Avatar
I have recently ran into an issue where the fan would not shut off even if the car was totally off.
turned out to be the blower resistor.
Old Nov 18, 2009 | 07:30 PM
vvod's Avatar
Default Re:
Thanks FCP
i'll try that out and get back to you
TCP
I've been reading around and have noticed that the resistor is only on the None-auto climate control. I have Auto-climate Control do you know if there is a difference?
mepammy
Sep 13, 2013 04:41 PM
jmallie
Sep 17, 2009 09:47 AM
Pyrate
Jun 15, 2009 02:17 PM
Evo 850
Dec 6, 2007 01:51 AM
Evo 850
Nov 24, 2007 05:25 PM
