Whining ..
Old Aug 13, 2004 | 12:01 AM
grahamk4y's Avatar
Default Whining ..
No not me whining, but I think the transmission...
There is a whining noise at speed - anything over 30mph ish, more noticable at 50-60. It comes from the front, and seems to be transmission (its an auto), but could be bearings.
Its done 120k, and just had new tyres on all round. Any ideas or relevant history ?
May be described as more of a grinding noise too...
Yours worried ...
Old Aug 23, 2004 | 07:08 PM
aseibel's Avatar
Default RE: Whining ..
Does the noise chane when you turn the steering wheel at hiway speeds?
Old Aug 23, 2004 | 07:32 PM
grahamk4y's Avatar
sort of, but not by much. A bit of a 'howl' now, though not too loud.
Old Aug 29, 2004 | 11:30 PM
grahamk4y's Avatar
Maybe more explanation...
A groaning/cyclical whine/moaning noise. Yes worse turning left but definitely evident straight ahead.
Local Volvo specialist quotes £150 for each bearing/hub, and assumes is a wheel bearing. Local garage not sure of cause fully, but now definitely worse since doing 500 miles in one day.
Main concern is - is it the gearbox instead, and can garage be sure that its a bearing.
Old Aug 31, 2004 | 05:59 PM
aseibel's Avatar
Does the noise correspond to engine rpm or vehicle speed? If it is vehicle speed it is most likely a hub bearing. A competent shop should have a tool like a chassis ear which can help isolate the noise while driving.
Old Jan 22, 2008 | 08:56 PM
Volvo V70R's Avatar
I know thisthread is forever old... but I think my car is doing the same thing... what was the resolution?
cetaphil
Mar 23, 2009 08:27 PM
conoros
Sep 27, 2006 06:50 PM
tupapison
Jul 24, 2006 10:16 PM
giacomozzi
Oct 20, 2005 09:34 PM
johnhon
May 22, 2005 09:55 AM
