turbo bypass
Old Aug 19, 2010 | 09:39 PM
darrick's Avatar
Default turbo bypass
Can turbo in s70 be bypassed so that it does not need any coolant or oil.Oil is mixing with coolant in turbo but coolant is not in oil.
Old Aug 19, 2010 | 10:06 PM
NO. Are you sure you don't have a bad head gasket?
Old Aug 22, 2010 | 07:48 PM
darrick's Avatar
not sure.The place that incorrectly diagnosed my car the first time says that its the h.gasket but of course I dont trust them now.Another mechanic said theres a hose behind the turbo thats leaking and i need a whole new engine.
Old Aug 25, 2010 | 10:09 AM
VolvoSwag's Avatar
I had a problem with my turbo recently and it was litteraly spraying oil every where and now its all gunked up with oil and its getting hand re built. If i would you i would check the turbo seals
Old Sep 12, 2010 | 01:37 AM
98S70T5IA's Avatar
do you mean that your turbo is getting hand rebuilt? or that your entire engine has to be rebuilt?
I only ask because I recently purchased a 98 T5 and the mechanic I go to said that the turbo was leaking, however it seems more like a weep than a leak.
I'm somewhat curious to the severity of this leak/weep. The turbo works great, no noise when it kicks on...the oil level is still perfect after 900 miles, and it leaves no spots on the ground.
Old Sep 12, 2010 | 05:10 PM
The weep/leak is the 1st sign of failure. From all I have read, it goes from a weep to leak, to smoking, then to failure. I would plan on doing something to it within 5k. Someone else maybe can give us more input on life expectancy.
deserts40
Jun 21, 2012 11:13 AM
volvoQ's
Dec 19, 2010 11:31 PM
neurd
Nov 24, 2006 02:35 PM
bigds
Aug 23, 2005 04:27 PM
fast850r
Jul 26, 2005 09:48 AM
