Engine question
Old Dec 29, 2004 | 06:19 PM
Andre760Turbo's Avatar
Default Engine question
I have always wondered on my dad's 1986 760 Turbo car if the boost can be easily raised without detonation. Can this be done and what type of boost controller do you guys recommend? Also I notice and hear a little bit of lifter noise when accelerating, is this common with these motors? Thanks.
Old Dec 29, 2004 | 06:27 PM
Default RE: Engine question
Also I was wondering if you can manually raise it..is that possible?
Old Dec 29, 2004 | 08:03 PM
You can turn the boost up a little by adjusting the waste gate valve.You can also T the vaccum line to the waste gate and install a pressure regulator.The tapping is probably the valves needing to be adjusted.
96850urbo
Jan 23, 2009 01:00 PM
Adrenalin540
Dec 31, 2008 10:19 AM
Aaronius
May 30, 2008 06:10 PM
pvolvoman
Oct 24, 2007 07:29 PM
mordezmoncou
Apr 9, 2007 05:22 AM
